high pitch squeal from rear end (?)
Old 07-03-2007 | 01:02 AM
calvert's Avatar
Default high pitch squeal from rear end (?)
I have a 1979 Camaro Berlineta. recently a high pitch squeal has been coming from the back right end. The squealing stops when I press on the brakes.
I added 90w to the rear dif. there has been no change.
Has anyone dealt with this?
Any ideas?
Old 07-03-2007 | 10:39 AM
bluovlh8er's Avatar
Default RE: high pitch squeal from rear end (?)
how are the brakes
Old 07-05-2007 | 08:32 PM
t9ojetpilot's Avatar
[X(] i do believe kind sir a peek at the brakes is in order. oil bathed parts generally (inside the rear end) dont produce high pitched squeals. the brakes however are a well documented culprit of high pitched squeals. take a look at the brakes on the offending side, dust and metal to metal spots are the common causes of annoying problems kurt
red star
04-14-2012 10:01 AM
1bad94z28
03-29-2010 07:14 PM
hevymetalg
03-20-2008 07:03 PM
