Help me locate Coolant leak
Hey guys. As you know... I've recently aquired a 97 z28. It's leaking right in front of the right front tire. It looks like it's underneath the resevior. You guys got any ideas?
Mr Alih is right once again!! Look at the lower radiator hose. You should be able to see the area where the hose is leaking if in fact that is the one. Plus Alih pointed out something that most people, including me, overlook. I had a leak in that same area and it ended up being my reservoir. It actually cracked and was leaking.
