gas pedal is loose..
RE: gas pedal is loose..
My gas pedal stuck like hell for months. I finally took the intake duct off the throttle body and brushed around the butterfly valves with some carb cleaner. Definitely helped, but I didn't scrub it as good as I wanted to. I should take the whole tb off sometime, but I haven't felt like it.
Who cares, btw?
Who cares, btw?
if you are talking about the pedal wiggles, and the metal rod that runs threw your firewall doesnt. Its just a screw or something you can tightn up behind the pedal, or maybe put a washer in it or something? get a flash light and lay on your back on the floor board if you can fit, or maybe a mirror or something and check it out. Im sure you can figure a way to shim it.
Camarodude,
Take a look at this 2001 Camaro Accelerator control diagram. This diagram illustrates all of the components in the gas pedal assembly on your 2001 Camaro. I don't remember which bolt you have to tighten down in order to solve the loose pedal issue but it's one of the bolts/screws displayed
