Front Right Wheel ABS tripping or bad Brakes
Old Feb 26, 2008 | 03:56 PM
DrRuckus13's Avatar
Default Front Right Wheel ABS tripping or bad Brakes
I have a question for the Guru's at Camaroforums.com
I have a problem with my 1997 Z28. The Frontleft tire keeps setting off the ABS or Traction control when stopping. Do you think it is bad break fluid causing the wheel to lock and set off the ABS and ACR. or do you think it is a sensor somewhere.
I have never flushed the system because I was told to do it with the plugs at 100,000. Actually i was told to never waste my timeflushing it byGM servicebut it was recomended by some car sites.
Old Feb 26, 2008 | 04:23 PM
Default RE: Front Right Wheel ABS tripping or bad Brakes
Each front wheel has a speed sensor plugged into the hub housing. Possible causes are: special flex wiring connecting to the wheel sensor damaged, a bad electrical connection, bad sensor, worn out hub bearing allowing the tone wheel to wobble, warped rotors, dragging brake pads, bent wheel, unmatched tires, unmatched tire pressure.
rktect69
Feb 25, 2012 06:46 PM
auto
Oct 8, 2009 01:19 PM
n269nando
Aug 1, 2009 07:01 PM
mstephens20
Apr 5, 2008 03:39 PM
chrismorales75
Sep 24, 2007 03:54 PM
