External Differances in Four Bolt Main?
Old Apr 28, 2006 | 11:42 PM
fenderboy's Avatar
Default External Differances in Four Bolt Main?
HEy i am new here and this has probably been covered before. I searched with no luck but anyways, how can I tell if the engine has a four bolt main from the outside while still in a car (in a jukeyard)?
Old Apr 29, 2006 | 01:57 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: External Differances in Four Bolt Main?
you would need to look up the casting number.i dont think there is a appearance difference in a 2-bolt or 4-bolt block.if you have the numbers go to www.mortec.com and look it up
Old Apr 29, 2006 | 02:50 PM
There is no external difference between 4 bolt and 2 bolt main set up. Even the casting numbers are the same, the difference takes place during the machining operation at the factory. However; there are some special purpose blocks that are not installed on the assembly line, such as the Bow Tie blocks, that only come with 4 bolt mains.
Old May 3, 2006 | 12:53 AM
1969 SS's Avatar
you can usually get a good guess by the year and what it came out of. not a true read but you are bettering your chances
libertyforall1776
LS Series Tech
Jul 24, 2009 04:29 PM
Jville_hot_skate
Dec 6, 2008 10:34 PM
gozzy341
Nov 4, 2007 08:52 PM
JYori
Nov 26, 2006 10:25 PM
mcge383
Nov 10, 2006 11:53 AM
