engine misfire
Old Jul 18, 2006 | 10:13 PM
froggy22's Avatar
Default engine misfire
I have a 98 Camaro 3.8 v6 auto transmission. I just had the plugs and wires changed and now I am getting a P300 error message on the scanner indicating misfire. I checked all the wiring and made sure it was correct. Should I have had the ignition coil replaced along with the wires?
Old Jul 18, 2006 | 11:53 PM
MadMikeZ28's Avatar
Default RE: engine misfire
Is the code just there or is it running. I dont know what your scanner is capable of because it could be a memory code. Also drive for about 25 miles to clear the monitors.
Also OBDII will compensate very well for a problem. Check and make sure all your plug wires snaped on good. I had started a 96 Astro van and forgot to put on 3 of the 6 wire and the damn thing ran. Ran rough but it did run.
audioshiver
Nov 1, 2012 04:06 AM
LCOAXUM
82-92 V8 Tech
Nov 26, 2008 10:41 PM
gquatro95
Nov 10, 2007 12:02 PM
94CamaroSFI
Aug 1, 2007 11:20 AM
RickPA
Feb 6, 2005 10:17 AM
