??? Emergency Brake Cable Removal ???
Old 10-08-2007 | 03:55 PM
73 T Top's Avatar
Default ??? Emergency Brake Cable Removal ???
How do you remove the emergency brake cable off of the rear drum brakes? I have a 1973 Camaro and I need to disconnect the cables so i can pull the rearend away.
Old 10-08-2007 | 06:57 PM
MadMikeZ28's Avatar
Default RE: ??? Emergency Brake Cable Removal ???
Either pull the drums and remove it fron the lever on the shoes and squeeze the tabs on the houseing to push it through the backing plates or follow the two under the car to where they meet the one cable and loosen the adjuster and remove it from there.
Old 10-09-2007 | 08:10 PM
t9ojetpilot's Avatar
[&:] its easiest to use a small hose clamp to compress the 3 spring pins on the cable housing or if you pull or push the cable housing on the backside of the backing plate in the direction opposite each pin and push each pin down and out the hole individualy kurt
Tomplayer105
09-10-2013 12:21 AM
black95z28
06-15-2009 12:48 AM
importmd
05-07-2008 11:19 PM
mrrilla
01-15-2008 10:36 PM
mikem290
08-15-2007 01:41 AM
