Damn thing wont start
Old Mar 7, 2008 | 01:05 PM
mrmadd02's Avatar
Default Damn thing wont start
i changed the radiator in 95 Z28 and put it back together now it will crank but wont turn over. checked the sparkplug wire with screwdriver and got no spark.
Old Mar 7, 2008 | 05:11 PM
Default RE: Damn thing wont start
If the car was working OK before you worked on it, one would assume that you did something to it to keep it from working. A guess would be that some ignition primary wiring got damaged or unplugged. You should retrace your steps and check everything out near where you were "working". Hopefully, you did not soak the Optispark with coolant and killed it.
Old Mar 7, 2008 | 05:15 PM
t9ojetpilot's Avatar
[&:] ditto there pete recheck connections and look around for items that may have been broken or tweeked during your install
75stroker383
Jun 29, 2011 09:17 PM
jason7504
Jun 6, 2009 12:16 AM
swp5767
Nov 3, 2008 12:33 PM
robmnrd
Mar 19, 2008 08:08 AM
