Coolant Fans and Blower
Old May 3, 2009 | 05:26 PM
hp1cart@yahoo.com's Avatar
Default Coolant Fans and Blower
A friend of mine has a 1994 camaro, I have assisted him in replacing the water pump and the opitspark. After replacing both the fans and blower will not come on, so when idling the car for about 10 minutes or driving the car it immediately hits up. I would like to know if anyone has run into this problem and what their fix was.
I am currently troubleshooting the problem and I have found the fix.
step 1 replace water pump and optispark
step 2 replace thermostat in water pump
step 3 replace fuses in fuse relay panel.
step 4 need to check out motor blower and cooling fans....
Old May 3, 2009 | 06:09 PM
02StanGT's Avatar
Are you referring to the blower for the HVAC inside the car?
Old May 3, 2009 | 06:28 PM
whitealexander's Avatar
i'll try this one out thanks for the tip though..
Old May 3, 2009 | 06:32 PM
Yes, I am but I am also referring to the cooling fans. I have found several forums which could help, but I put it out there to see if anyone has good suggestions.......
Old May 3, 2009 | 06:47 PM
ManOfBusiness's Avatar
If It Worked Before replacing those parts, Id suggest double check your work, fan relay would be the next check.
good luck.
Old May 14, 2009 | 06:36 AM
micheljaw's Avatar
very nice...
AnalyzeFaith
Dec 5, 2010 05:54 PM
ss2263
Mar 20, 2009 07:01 PM
70_boosted
Jul 7, 2007 10:43 PM
Monedogg
82-92 V8 Tech
Dec 22, 2006 10:11 AM
Jimbo
Nov 7, 2006 01:38 AM
