cold start valve????
Old Apr 20, 2006 | 03:54 PM
dzroc's Avatar
Default cold start valve????
A question for anyone who can help.I have a 1989 iroc z28 350 tpi auto. The car will only turn on if i spray carb cleaner into the throtlebody.My haynes repair manual show a cold start valve on the intake by an injector,my car dose not have it.My question should i have it?Could that be my problem?Has any one had that problem?please help!! thanks.By the way i put a new cap and rotor ,wire,.spark plugs,did the timming fule filter,fule pump.Im stumped.
Old Apr 20, 2006 | 06:12 PM
SickSickSick's Avatar
Default RE: cold start valve????
Does It Continue To Run After You Crank It With Ether Or Does It Die Out? Sick
Old Apr 20, 2006 | 07:49 PM
dzroc's Avatar
the car will start only with carb spray or a little gas in the throttle,otherwise it will only carnk.
Old Apr 20, 2006 | 07:57 PM
But Does It Continue To Run Or Does It Stall Out After It Burns The Fuel You Put In The Throttle Body? Sick
Old Apr 20, 2006 | 08:07 PM
dzroc's Avatar
yes it will continue to run after it burs wat i sprayed, but if i turn it off i have repeat yhe process. could it be the fule regulater?
Old Apr 20, 2006 | 08:42 PM
dzroc's Avatar
I am all out of ideas, im almost ready to sell her
Old Apr 20, 2006 | 09:27 PM
Hmmmmmm ... Is The Check Engine Light On?
Old Apr 21, 2006 | 03:13 AM
dzroc's Avatar
the check engine lite comes on once in a while for about 5 seconds. but not recently.I dont get it! when it turns on it runs like a champ!!!I bought the fule regulator diaphram (only $35)the rebuild kit i guess.Ill put it on tonight and ill let u know wats up.
Old Apr 21, 2006 | 09:39 PM
Another Thing You Might Check ... Turn The Key On And Listen To See If The Fuel Pump Primes Up. Sick
Old Apr 22, 2006 | 12:28 AM
From what I can understand, the car will run OK if you manually prime it with fuel.
To me this indicates the fuel pump is OK.
Check the fuel pressure while cranking, should be over 40 PSI
No pressure, check the fuel pump priming relay.
How it works:
The fuel pump is provided power via two different paths.
When cranknking, power to the pump is provided by the pump relay.
Once running and oil pressure is over 5 PSI, power to the pump is also provided via a switch incorporated into the oil pressure sensor.
Being that the engine will run OK once started it shows thwt the oil pressure sensor is OK
If you are able to crank the engine fast enough to bring up the oil pressure, it will start even with a bad pump relay
