carburetor replacement
Old Nov 13, 2007 | 06:06 PM
Saint_Ali's Avatar
Default carburetor replacement
ok im lookin at a 85 t/a for sale that needs a rebuilt carb, its a computer controled one, could i run a non computer controlled one on it ? would there be any problems ?
Old Nov 13, 2007 | 06:56 PM
t9ojetpilot's Avatar
Default RE: carburetor replacement
[&:] you certainly could but it means removing/not using the computer controls for the whole engine/trans engine(will need an older hei as well) with these two it should work. might consider removal of the cats for later use and to avoid destruction if mixtures are not right at first. also at least here in the states this would all be a big no no for a street driven/ emissions tested vehicle. will not pass a standard visual and emissions check if required in your area kurt
Bjm3.8
Oct 19, 2010 08:07 PM
logankarshner
Dec 13, 2009 03:19 PM
bvans
Aug 4, 2009 01:16 PM
jason14227
Jan 31, 2008 11:42 PM
firefighter47
Apr 12, 2005 09:14 AM
