carburator issues
Old Nov 6, 2006 | 12:57 AM
hotrodguy1986's Avatar
Default carburator issues
i was just wondering witch would be a better performance carb for my 355sbc. it is built for a 700-750cfm easy i was just wondering what kind to use some say the double pumper, street avenger or even the edelbrock performer. economy is not a big concern so any input would be appreicated
Old Nov 15, 2006 | 01:28 AM
uncle bill's Avatar
Default RE: carburator issues
Holleys are pretty safe if You leave them alone. A Double pumper is going to give Yoy gas when You want it, the rest rely on the ennine vacuum for secondary blabes to open. Go from there.
Old Nov 27, 2006 | 10:49 PM
69camaro1's Avatar
I think that a vacuum secondary 750cfm holley single pumper will work great. I wouldn't go with the double pumper because thats more gas then you need.
Old Nov 28, 2006 | 10:02 PM
JD1969's Avatar
Whats the complete set up? trans type, rear gears, cam specs?
Old Nov 29, 2006 | 07:53 PM
SickSickSick's Avatar
if you body is stock weight i would stay away from the mechanical secondaries. vacuum secondaries are best for a heavy body. Sick
Old Dec 7, 2006 | 04:16 PM
my body is stock and the whole set up is holley systamax II kit with aluminam heads, street dominator intake, roler rockers, forged crank, eagle rods , forged dome pistons, lunati cam .290/.297 dur .490/.490 lift 110degrees lobe seperation, b&m th350 with 2800rpm stall, 3.42 eaton posi, 26in tall indy profile ss,msd ignition system with hei distrbutor 10.7-1cpr. at idle i only pull around 10in of vacuum. and also what kind of power do you think it will make
Old Dec 7, 2006 | 06:04 PM
with that cam not a as much as you are hoping. doesn't have very much lift for a bored 350. i run about the same cam in my 305. your gonna over carb with a 750. Sick
Old Dec 7, 2006 | 10:58 PM
rat454's Avatar
Is this a street racer or a track only racer....
are you running a rev limiter.....
street racer ... Edelbrock 1812 800 CFM... manual choke
track ... holley 800 sqaure bore.....since it's an auto, I'd run a vacum secondary, tuned right it'll do ya good,
Old Dec 8, 2006 | 01:30 AM
it will be a street strip car i was just worring that i don't have enough vacuum, for a vacuum secondary carb
Old Dec 8, 2006 | 01:33 AM
also holley claimed with that setup and a double pumper you can get about 425hp out of the motor and that is all i am really looking for
