A/C Problems
A/C Problems
I have a 97 Camaro 3.8L V6. My A/C used to switch from the face to blowing on the floor when I would accelerate or down shift and now it is doing it all of the time and will only blow on the floor board. I was thinking it must be some kind of vacum problem since it only did it when I accelerated but I have no idea. Any help would be appreciated.
RE: A/C Problems
There is a bunch of vacuum valves tht work the air doors in the AC plenum. You need to get under the dasboard and look for vacuum leaks, broken hoses, broken valves, stuck air doors, micenest,etc.
RE: A/C Problems
ORIGINAL: z28pete
The PCM will turn off the compressor at WOT in order to give all power to the wheels.
