Brake light help!!!!
Old Jul 30, 2011 | 07:18 PM
Mech1353's Avatar
Default Brake light help!!!!
Hello-
I just bought a 97 camaro and the brake lights after replacing the bulbs work, however at night when I turn on the headlights the brakes turn on with the headlights and when I depress the brake to actually engage the lights they turn off (except the center brake light on the spoiler). The car supossedly had been parked for over a year, and I was not told this was an issue. The brake lights work fine during the day without the headlights on. Any thoughts?
**I re-ran the wiring system in the back today and still having the issue.***
Old Jul 30, 2011 | 08:06 PM
hevymetalg's Avatar
Subscribed! Wtf that's crazy man?
Old Jul 30, 2011 | 10:58 PM
May just be the wrong bulb number, damaged or shorted bulb socket, or in a dual filament bulb, the filaments are shorted to each other. Possibility, not a promise.
Old Jul 30, 2011 | 11:24 PM
are you sure the bulbs are in the right way, you can get them in backwards if you try hard enough.
Old Aug 1, 2011 | 07:51 PM
Stevolwevol's Avatar
Sometimes the sockets have oxidation on the terminals, causing a bad connection. They can be cleaned with WD 40 , and a Q tip. It's worth a try.
Socom
Nov 9, 2013 01:41 PM
hpd218
Aug 24, 2010 12:05 PM
MegzZ28
Nov 27, 2007 01:47 PM
Skiwee10
Aug 31, 2006 12:54 AM
The_Shadow
Dec 2, 2005 07:59 PM
