Brake light help
Old Aug 6, 2008 | 10:36 AM
dletner's Avatar
Default Brake light help
i have a 98 camaro and my e-brake light will not go off. does that mean i need new pads? also my e-brake does not work.
Old Aug 6, 2008 | 11:24 AM
Default RE: Brake light help
Either there is a problem with the E brake switch, or more important you have a brake system problem, such as low fluid, or unequal pressure between the 2 master cylinder sections, which would indicate 1/2 of your brakes are in trouble. Get the brakes checked out.
Old Aug 19, 2008 | 07:22 PM
dletner's Avatar
i just bled the breaks and it fixed it
Old Aug 20, 2008 | 11:45 AM
MadMikeZ28's Avatar
So Z28Pete was correct in the unequal pressure response
Socom
Nov 9, 2013 01:41 PM
hpd218
Aug 24, 2010 12:05 PM
MegzZ28
Nov 27, 2007 01:47 PM
Skiwee10
Aug 31, 2006 12:54 AM
The_Shadow
Dec 2, 2005 07:59 PM
