blinker problems
Old Aug 17, 2006 | 01:38 AM
klxrider3214's Avatar
Default blinker problems
ok i did a search and couldent find a direct answer although there probably is one on here somewere
i just bought a 1987 z28, there are 2 problems the blinkers dont work, checked the fuse, there was none so i put it in, now the blinkers dont blink its just a solid light, the hazards work in the front but not the back? the other thing wich im not too worried about is there is no horn it has an aftermarket steering wheel and no horn how is this fixed?
thank you for the noob advice
Old Aug 17, 2006 | 01:28 PM
yellowjacket01's Avatar
Default RE: blinker problems
as far as the blinkers go,i was told that there was a relay that controls the blinking as to where it is i have no clue,trying to do that myself...the horn they may have not gotten the right adapter,take the wheel off and inspect it.
Old Aug 17, 2006 | 07:43 PM
02renegade's Avatar
check all the bulbs, sometimes a burnt out bulb will cause strange troubles. There is also a flasher somewhere near the fuse box probably that controls the blinking.
Old Aug 18, 2006 | 12:00 AM
stopped by napa got a new flasher put it in, the front blinkers work but not the back i guess ill have to try new bulbs and if thats not it then grounds? also the heater does not work i do not think it is hooked up, the guy i bought it from was swapping engines in and out so i do not think that the heeter is working now? he siad he ripped out the a/c but didnt mention the heeter, there is no fans at all, where do i start to look for this also there are 3 third gen camaros in the junkyard a few miles down the road
ArboisElevated
Oct 20, 2013 10:53 PM
Kimberly Lindsey
Jan 6, 2013 05:02 AM
Blue79Camaro
Aug 17, 2009 09:26 PM
dletner
Sep 21, 2008 06:23 PM
dletner
Aug 26, 2008 09:37 PM
