automatic to 5 speed conversion help
ok, im putting a 5 speed transmission in to replace that old automatic transmission with a bad torque converter, everythings cool except the brake pedal is very wide due to it being an automatic, i somehow need to make the brake less wide to make room for a clutch,
any suggestions
any suggestions
your putting in alot of work. theres a ton of stuff you need to swap them out. do u have everything? like the center console an crap. but what i'd do about the pedal thing is go out to a junk yard an get the pedal off another 5speed an put it on there.
Camaro 69
Mar 6, 2013 09:54 AM
