ABS & SES Light
Old Jun 12, 2009 | 06:13 PM
kummy75's Avatar
Default ABS & SES Light
Well my ABS light is on but it doesn't come on whenI start the car. It only comes on when the car starts to move a little bit. I'm thinking it is one of the speed sensors in the wheel or the diff. For the wheel Sensor you need to buy the entire hub for 160! I don't want to have to buy both hubs only to find out it wasn't even the problem or I only needed one hub. Is there a way to pull the code or do I have to take it to a shop?
The second issue is my SES light. I think it has something to do with my Secondary airpump. The light doesn't turn on at startup but turns on when I begin to drive and turns off when I am stopped at lights. The air pump blows fuses but today I put a new fuse in and it lasted awhile when I drove the car with no SES light. I hooked the car up to a scanner to pull the codes and it said it didn't have any stored codes. Is there way to test the pump or is the pump a common thing to go bad? I don't want to spend $160 to replace the pump when it could be fixed.
BTW my car is a 95 z28 automatic with electric water pump. Thanks for looking. Sorry I know I sound like I'm being cheap but money is tight and I know for sure I need new shocks and struts because they are beyond dead!
Old Jun 12, 2009 | 08:50 PM
Spend the $50 and get the ABS scanned wit an ABS scanner. Much cheaper than throwing parts at the problem. Also make sure you have the same size tires all around.
Old Jun 12, 2009 | 10:29 PM
kummy75's Avatar
different tire sizes will make the ABS light come on?
Socom
Nov 9, 2013 01:41 PM
Rent
Apr 22, 2013 11:08 PM
hpd218
Aug 24, 2010 12:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
dustinb
Oct 1, 2007 06:58 PM
