96 Z won't start!
Old Jan 4, 2008 | 11:30 AM
Clod_Z28's Avatar
Default 96 Z won't start!
Ok here's the scoop. I have a 96 Z 28 with 105,xxx all stock. About two weeks ago it died on me while I was driving. Iput some gas in it and tried to start it, no luck, I came back an hour later and it was just fine.I thought it was out of gas because my gauge is a little off, but that's not the case nowbecause I know it has 3/4 of a tank in it. When I turn the key it cranks over just fine, just doesn't want to fire. Fuel pump? There is a check engine light on, but I haven't been able to find someone with a scaner to see what the code is. Any ideas?
Old Jan 4, 2008 | 12:06 PM
jdubs1813's Avatar
Default RE: 96 Z won't start!
When was the last time you did a tune-up?Maybe try replacing all that. I wouldn't go straight to a fuel pump because it's the hardest and most expensive fix.
Old Jan 4, 2008 | 12:29 PM
Clod_Z28's Avatar
I can't say that I've ever really had a tune-up on it, I've ony had the car for 2 months. When I bought it I put a new fuel filter, thermostat, belt, and ran some sea foam through it. I guess I need to find someone with a scanner willing to come over and check it out.
Old Jan 5, 2008 | 10:11 AM
Clod_Z28's Avatar
Last night I tried to start the car again just to see what would happen and it fired up for about 2 seconds, I also notice that the alarm didn't go off on my car when I opened the door and didn't put the key in within so many seconds. Then I locked the car and then unlocked it and didn't put the key in for a few seconds and the alarm went off, but the car wouldn't start. Does this sound like the security system could be what's not letting the car start?
Old Jan 8, 2008 | 02:09 PM
buckfever's Avatar
well if you ran the tank dry at one point you coulda burned up the fuel pump so its possible.. just check your fp at the schroader valve to test the pump
Old Jan 9, 2008 | 12:53 PM
Clod_Z28's Avatar
I did a fp check last night and I had nothing. Does anyone know how to change a fuel pump without droping everything out from under the car?
Old Jan 9, 2008 | 01:25 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You can get a rapair manual at the same place that has the part, usually autozone or advance auto. If haynes is the only thing you can findd its ok. I prefer chiltons. You will learn how to replace the fuel pump form there. I would get the check engine light looked at first though. Could be something simple.
The security systemon these cars have been known to go haywire. You might get some info if you called the local Gm service dept and see if they could tell you how to reset the system.
Old Jan 9, 2008 | 02:28 PM
Clod_Z28's Avatar
P1441 is the code, this would make since if the fuel pump was bad. I bought a Haynes repair book when I first bought the car and it is very handy, but the only way they show to replace the pump is to drop the rear end and gas tank.
Old Jan 9, 2008 | 03:29 PM
maroman209's Avatar
i got this link from 02stang... fuel pump exchange without taking everything out...
http://home.comcast.net/~grayman99/Fuel-Pump.htm
Old Jan 9, 2008 | 05:06 PM
Before you change the pump, verify that the pump itself is bad and not some electrical problem such as the pump relay or wiring. There is a test/prime connector on the passenger side of the car above the fender well. With a jumper wire connect 12 Volt from the battery to the test connector. If the pump now works, there is an electrical problem, if the pump is dead, then you can be sure that the pump is bad.
Test connector: http://shbox.com/1/fuel_pump_prime.jpg
Fuel pump relay: http://shbox.com/1/fuel_pump_relay.jpg
