96 Camaro battery dies even when off
Ok so my car battery was dieng<(watever i dont know how to spell it) anyways it was overnight and after testing the alternator i found that it was faulty, i bought a new one and found it worked the batteryw ould recharge and it would stay on while driving, but now when i park it the next day its dead again, i dont know what the problem can be but if anybody has any suggestions im open to all your help
RE: 96 Camaro battery dies even when off
Did you check to make sure no lights are stuck on when you park it...glove box, underhood, trunk?
What was faulty on the old alternator, poor output or an internal short?
You can disconnect the positive battery cable overnight and see if the battery holds it's charge. Sometimes a bad battery will work as long as it has a fresh charge, but can discharge on it's own overnight.
Or, you may have a short somewhere. Disconnect the positive cable at the battery, and connect a volt meter between the cable and battery post. Check your reading, then start to pull your accessory fuses one at a time until you see a deflection in the meter.
Let's back up and start from the begining.
The alternator failed and is now replaced. The battery dies you mention. You haven't mentioned if the battery has been properly tested yet. I don't care if it's new, a month old or five years old. Testing the battery is the first thing to do with any electrical problem. It is possible a faulty battery with a bad cell caused the death of the alternator and may kill the new one. Even charging it and leaving the cables off over night you may still have a no start in the morning if the battery is bad.
And I would highly suggest never taking the battery cables off with the car running, you run the risk of making the alternator full field and burn up. Even a new unit. This used to be a ok thing looooong ago but with the light wieght alternators and electrical circuits in cars from the 70's on it's a problem waiting to happen.
UPDATE: I took the battery to kragens and im due for an answer in like 45mins but the alternator i removed tested + and passed all 3 checks so if its not the battery it think it might be a short
UPFATE: Just found out it was a bad cell on the battery its only 1 months old but im getting it exchanged for free so thanks EVERYBODY uve been very helpful
Well glad you found it.
But I will second everything Williesrepair said. Specialy that part about Not disconnecting the battery. I cringed when I read that. I thought cplthomas knew better.
ORIGINAL: carnage9
And, since some of us are in a particularly helpfull mood, maybe there wont be as much cringes when you read this one.
https://camaroforums.com/m_220376/mpage_2/tm.htm isnt the desperation sick!
libertyforall1776
02-24-2014 03:11 PM
