95 camaro
Old 03-06-2010 | 03:57 PM
xX-user name-Xx's Avatar
Default 95 camaro
hey hows it going ppl, i need some help with this mega problem i have with my 95 camaro. its all completely stock, v6....so this is wut happen, i open the door to my car and the lights or the beeping noise from the door being open was not working, i turn the key over and all the gauges work along with the exterior lights. the battery is not dead but for some reason the car wont even budge with the key all the way forward to start it. i put a new neutral safety switch in the car this morning and it didn't change. my car is a manual by the way. if anyone has a clue whats going on your help would be appreciated. i can be reached at 760-207-9265....so-cal......my name is jake, thank you
Old 03-06-2010 | 10:44 PM
osduck5's Avatar
Remove the battery cables and clean the terminals. If that don't work, check all your fuses and if you have an ohm meter, test for battery voltage on the starter soleniod when the key is in the run position.
Old 03-07-2010 | 12:19 PM
I sthe security light ON when you try to start?
Old 03-07-2010 | 07:13 PM
JordanT's Avatar
With a manual it will not start until the clutch if FULLY depressed. Make sure there is nothing hanging the clutch pedal up and I assume there is some sort of switch up there, make sure that is all good.
Old 06-14-2010 | 02:06 AM
Chaotic94's Avatar
September 2011 ROTM
Mine did this about a month ago. Something between the clutch and the computer was telling the computer that I didn't have the clutch all the way in and my car wouldn't do anything. I'm not sure what the issue was because I had it fixed for $165. Mechanic said something about a broken linkage?
