94 Z28- Washed my engine, now it wont start
Old Oct 4, 2008 | 07:31 PM
Sniper's Avatar
Default 94 Z28- Washed my engine, now it wont start
I have an 94 Z28, I know, I know..... But I did it , I sprayed engine cleaner all over my motor. I followed all the instructions. Hosed it off. Started it up. After that it would not start!!!!
Is it the Opti Spark? I hope not, what can I check for first before going and replacing parts?
A while back I had a similar problem with my 97 v6 camaro and my friend came in with a blow dryer and he dried some stuff and got it to start (and no I didnt wash that one) but I know this is a different engine and possibly not as easy to fix?? I really need help.
Old Oct 4, 2008 | 08:44 PM
blackz87's Avatar
Default RE: 94 Z28- Washed my engine, now it wont start
Opti-sparks are wet, let it dry out overnight. Then hope you didn't damage them.
Old Oct 4, 2008 | 08:56 PM
Sniper's Avatar
Ok, thanks, I will wait and see, hopefully it will start
Also, trying to start it at this point can drain the battery too right?
Old Oct 4, 2008 | 10:05 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Yes.
Wait till its dry.
Old Oct 4, 2008 | 11:28 PM
95slvrZ28's Avatar
If you already tried to start it and it was the opti more than likely you've already toasted it. Wait a little and see, good luck...
Old Oct 5, 2008 | 05:52 PM
Sniper's Avatar
Well I tried to today and got it to turn on, I turned it off and I couldn't get it back on, Should I have left it on for a while? I think my battery is dying. Any Ideas what it might be still, could it still be the optispark?
Old Oct 5, 2008 | 07:09 PM
blackz87's Avatar
ORIGINAL: Sniper
Make sure the battery ia ok and try again.
Old Oct 5, 2008 | 07:20 PM
Sniper's Avatar
Yea when I got it to start, I actually had to jump start it.
Old Oct 6, 2008 | 05:56 AM
blackz87's Avatar
Well let that a lesson for you, go easy on the water in the engine compartment. At least on the electrical parts.
Old Oct 10, 2008 | 03:25 AM
Sniper's Avatar
Well.. My Car Works!! Ahh Im so happy now lol. So this is what happened, I called my friend who knows more than me about cars, so he starts checking basic things one night, he couldnt figure it out so we try again the next morning with more light. Again, he starts checking the hoses and electrical components. Then he starts pulling off the spark plug cables, when he was about to pull the ignition cable off, it basically broke apart.. He was like, this old cable might be the problem, so we go and buy a new set of cables, give the car a jump start, and Vroom! My LT1 is alive again.. There was also like this white rust stuff on there so he cleaned it off and it even turns on faster now! I dont see what that had to do with me weting the engine but ok, Im glad it wasn't the opti spark, I really didnt have the time nor $ for that much work right now. 5 Days without your car can make you go crazy.. Phew.. but anyways, thanks to those who tried to help me out.
and yes I know, lesson learned, never again
sharp
Jun 13, 2013 03:57 AM
uestraven
Mar 15, 2011 12:32 AM
ggraham
Mar 11, 2011 10:13 AM
ggraham
Mar 11, 2011 04:08 AM
dhighway
Mar 8, 2008 06:36 PM
