94 z28 heat not getting hot
Old Jan 21, 2009 | 03:03 PM
jwelches88's Avatar
Default 94 z28 heat not getting hot
I have a 94 z28 and iam having problems with my heat. when u turn the heat on the air comeing out of the vents is like luke warm. i know my heating core is good because its not leaking plus the car runs fine so i dont know wat it can be. My car runs at about 180 but proly a little less. can there be a circulating problem with my wate? I also changed my thermostat and still no help. Plus in which direction the antifreeze flow to the heater core ( for example, goes in the top hose and exits the bottom hose or vise versa)
Old Jan 21, 2009 | 04:10 PM
bluovlh8er's Avatar
ok brother you want your heat fixed listen to me............
you have a clogged heater core. trust me! now you can try flushing it but it will only last so long, i flushed my z28 out like 3 times last year.
finally just sent $70 at autozone for a brand new one and havent had a problem since.
not the **** like nice and hot! not that ice cold problem...
Old Jan 21, 2009 | 11:54 PM
Y2K's Avatar
Y2K
Yup,just had a new one put in mine,pretty common problem with these cars.
Old Jan 21, 2009 | 11:58 PM
Saint_Ali's Avatar
the thermostat could also be stuck open
Old Jan 22, 2009 | 01:43 AM
95slvrZ28's Avatar
Is it just the heater that isn't working, or does the temp gauge stay low as well?
Old Jan 22, 2009 | 03:53 PM
jwelches88's Avatar
Default heat not working
the temp use to stay below the first line ( i dont know what temp that would be ) but i changed the thermostat and it now runs a little under the halfway line. but even with the car running a little hotter the air that is blowing out still isnt hot. Also i put a thermometer in the radiator and it reads 102 degrees when the thermostat says its higher. Also the engine fans pretty much are always on. Last i changed the head gaskets at the end of last winter and i know the heat worked before that, so do you think there could be a problem there?
Old Jan 22, 2009 | 04:23 PM
bluovlh8er's Avatar
[QUOTE I also changed my thermostat and still no help. QUOTE]
Old Jan 22, 2009 | 07:52 PM
jwelches88's Avatar
Default heat not getting hot
didnt help the air get hot, it was still blowing out cold air
Old Jan 25, 2009 | 01:41 PM
jwelches88's Avatar
yea it was a clogged heater core. i guess wen i tryed the air compressor didnt work bc i shot water through the core and a hole bunch of build up came out and my heats workin better now. thanks
Old Jan 25, 2009 | 09:20 PM
bluovlh8er's Avatar
so did u flush or replace?
