1984 starter problem
Old Jun 15, 2008 | 10:35 PM
kid21988's Avatar
Default 1984 starter problem
ok i have a 1984 camaro and we just got a new battery, we checked the atlernator and then we got anew starter we put it in and it was catching the fly wheel so we shimmed every which way to try and get it to work and we cant are we just dumb or is there mabye somthing somone knows to heelp me and my friend out
Old Jun 15, 2008 | 11:17 PM
MadMikeZ28's Avatar
Default RE: 1984 starter problem
You might just be dumb. Mybe you should try another starter. I have seen them from rebuilders with the cone all out a whack. Some times you would need to just put a shim under one bolt and not the other to make some of these crapy ones work.
Old Jun 16, 2008 | 05:54 PM
kid21988's Avatar
yea we were thinking that so we broke the new one and then took it back and got another and we had the same problem so we pop started the car and it started so its not the fly wheel and we have shimmed both bolts both ways towards the fly wheel, away , up down every way its fustrating
Old Jun 16, 2008 | 06:23 PM
MadMikeZ28's Avatar
Is it not engaging or screaching? Did you hook the wires up on the correct terminals?
Old Jun 19, 2008 | 05:31 PM
hobby2's Avatar
Banned
Well you own a Camaro that's your first problem.
**Please refer to this link when reading my posts!**
https://camaroforums.com/m_220420/tm.htm
mobo
Oct 2, 2010 08:57 PM
RandyZ28
Aug 24, 2009 04:44 PM
missin
82-92 V6 Tech
Jun 27, 2009 02:37 AM
cjsuret
Oct 30, 2007 08:43 AM
Piero
Jul 19, 2007 06:13 AM
