racing advice
ok sooooo my daddy dont got deep pockets and i dont got a job where i can make 12 grand so i dont care bout the cobra no more what can i do to get the most out of my little rs for a way cheaper price and ill probly be making this car out of junk yard and used parts just i know for a fact a 350 is in store for the future
http://www.summitracing.com/parts/SUM-K1102/ its mild.. produces peak power around 5000 rpm. A HEI distributor(non computor) is fine for the rpm. The rear end in the car is a weak point you can try a gear change and a used posi it might hold up for awhile. It isnt the best way to go no doubt but its a starting point. Take it to the local dragstrip and play around with the tuning you will learn alot.
^^ good advice..
i would suggest, a complete vortec 350..from a junkyard, ive seen them go for about $500..and thats with the ecu, and wiring harness (thats what i now plan on doing) and basically do the full list of bold ons (intake, headers and exhaust, mild cam, and since there fuel injected motors get a tune..
and for rear end, my dad ticked up 2 12 bolts for $300 off of craigslist..and with a simple gear change and a clean up/ re greese..its gonna be able to hold his 500hp bbc..
theres alot of options out there..you just need to pick the right one for you
ok so say i put in a 350 vortec what kinds of intake and carbs should i look at my brother has a spare elderbrock carb and he says its a performance once just hasnt checked what kind yet. basically what could i do for the most hp.
ps i know i will need more support in the front and back end i have a friend who put a beefed up 350 in his 1989 and the front end started to warp he said. so what are some more ways to get that support i need so it dont do this
prolly a 650-700cfm carb..a nicely built sbc shouldnt need anything bigger..as for intake..if its gonna be a street motor get one that gets the best low-mid power (like 1200-4000) if its gonna be a more race less street motor get one that gets the best mid-high range power (maybe 2500-redline)..
unless your making a 700+hp motor you dont need a masive carb..you could actually be wasting fuel and trashing your mpg (from what my dad says)
you can can build that 305 up to have around 325 hp....if your tight on money i would do that and buy 4.10 gears if your wanting to do red light to red light kinda racing but if your wanting to do some other such as some high way i would go with 3.73 if your cool with staying under 150-160...but i would keep the 305 build it up put 4.10 in it you got 325 hp and then i would spay it put like a 75-125 shot on it then your pushing at least 400 hp...and by doing all this youll be spending a little over 1000 which isnt to bad but it saves you that few hundred when buying the 350...and if you dont like the 305 after you build it up i would just sell it and buy you a 350 now with some spending money...but if your looking around 400 hp i would do that...
this is what im doing to my camaro...
http://www.goingfaster.com/spo/325_h...chevrolet.html
rynoracer32
Professional Racing
04-11-2013 01:41 PM
sohcnick
03-25-2013 04:03 PM
1981camaroz28
10-23-2007 05:44 PM
