General Racing/Tech General talk about Racing or help setting up your car
ok wat you guys think it'll do?
Old Nov 21, 2008 | 12:04 PM
z28rob18's Avatar
Default ok wat you guys think it'll do?
ok well im starting a build ive been updating in the 4th gen section and now id lik to c some guess's on wat it'll run even though i wont get times till next year let me know wat you think. 1995 camaro t56 6 speed. will have a midwest fab 9" with there torque arm and sway bar and the strange driveshaft 4:10 gears. the t56 will hav some small upgrades to handle the power along with a new clutch and billet steel flywheel. the powerplant will be a 383 lt1 advanced inductions 200cc cnc'd heads with a custom grind cam probably around .612 lift valvetrain converted to solid roller with 1.6 pro magnum rockers. ported stock intake with a mono blade tb. 42lb injectors rotating assembly is forged. will have a 10pt cage and everything else for safety. doin some weight reduction hoping for 3400-3500lbs tires will be hoosier quick time pros and skinnies up front. oh and the most inportant thing a 200 shot wet. so what do you all think it will do?
Old Nov 21, 2008 | 01:58 PM
73camaroSS's Avatar
Default RE: ok wat you guys think it'll do?
13 flat on a cool night,jk i'm not a expert or any thing but i will guess around 11.8.
Old Nov 21, 2008 | 06:29 PM
Lee Willis's Avatar
3500 lbs sounds about right. Good plan overall. With the Hoosiers warmed up, I think you can do mid 11s or better. 200 shot? Better have plenty of margin in the fuel pump and system and a good wet system with a great tune and 42 lb injectors migth be just barely enough.
Old Nov 22, 2008 | 09:31 AM
z28rob18's Avatar
forgot to mention the fuel system will be upgraded so u really think low 11s? i was thinkin more of low 10s were plannin on 650-700rwhp on the 200 shot
Old Nov 22, 2008 | 01:29 PM
73camaroSS's Avatar
dont setyour standereds to high cuase 10 is a lot harder to get to then you think not to mention you better have some dam good suspintion and tires to handle over 600hp.
Old Nov 22, 2008 | 03:23 PM
robmnrd's Avatar
What he said. Add about 4000 in suspension goodies, and you've got your 10's. haha
iLL95
Sep 27, 2011 09:08 AM
97Maroman
Jun 26, 2010 11:03 AM
Mtowles
Mar 21, 2010 05:09 PM
