General Racing/Tech General talk about Racing or help setting up your car
launch
Old Aug 4, 2007 | 02:18 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default launch
basically i know most of the people who driven 3.8 like mine arent launching em anyway but while its no lt1 or ls1 i have fun with mine in the past ive been launching at about 1500 RPM im wondering be better to keep doing it from there or try and push it if i get much over 2000 Rpms with the breaks on my tires start to spin and burn out so ya
Old Aug 4, 2007 | 04:02 PM
TheStig's Avatar
Default RE: launch
when i was on my old crappy tires i could push it to about 2500. but after launch it would fishtail really bad. with my new tires and some practice she lunches very well. what size tires are you running? I have 245/50-16 and they do a pretty good job.
Old Aug 4, 2007 | 04:10 PM
BigNic's Avatar
Default RE: launch
im running stock size tires there called egale GT's there supposed to be "street preformace tires" lol i sure hope they i payed a arm and a leg for em [&:]
Old Aug 4, 2007 | 08:37 PM
TheStig's Avatar
Default RE: launch
ORIGINAL: BigNic
How new are they? My old tires were michilen Pilot XGTs and they were great tires, I just had very little tread left. I raced a guy from a dig with an arm drop & he took me off the line becuase i was spinning all the way threw 1st. (after I got traction I won) After I put my new tires on I luanched and found the sweet spot where I can luanch and let the tires scream but not really spin. It depends where your racing too. A few days after that I went to the track and off the line the tires hooked very well, no spin and no long scretching.
I guess the key is practice. Find a deserted street back somwhere near you live. (make sure its a strait line and you can see behind u & infront of you all the way down the street) Then just try launching her at 2K. If it hooks good, go up to 3K. If it spins to much go down to 2500...etc
Old Aug 4, 2007 | 11:17 PM
badinfluenceRS's Avatar
Default RE: launch
I had some sumitomo 9.5" rears so I could hold mine up past 2K and let it go, they'd chirp a bit and get traction VERY good
Old Aug 5, 2007 | 12:04 PM
BigNic's Avatar
Default RE: launch
i bought them like this march the tractions great though hard turns in the rain all that maybe im just not breaking hard enough
Old Aug 5, 2007 | 12:54 PM
Matt99camaro's Avatar
Default RE: launch
I don't how you all get that much tire spin. My back tires have maybe 1/4 tread left on them and no matter where I launch from 0rpm or 2000rpm, I get little to no tire spin. My car's not running like it did but I never got that much spin. Weird.
Old Aug 5, 2007 | 04:04 PM
TheStig's Avatar
Default RE: launch
ORIGINAL: BigNic
there is a trick to power brakes. You put it in neurual then press the brake pedal all the way to the floor. Then rev it up to 3K-4K rpms really quick and you should be able to press the brakes in even farther. after you let the RPMs fall back to idol (It should on take a second or 2) shift into drive and then try your launch.
Old Aug 5, 2007 | 04:17 PM
BigNic's Avatar
Default RE: launch
i tryed to break harder today in my works parking garge got it up to 2000 rpms fine at 2200 they started to spin and burn out but some of the guys i know were coming back from lunch so i just let em burn for a bit cus they were cheering me on but i did get to 2000 so im glad about that
terrychamp01
Aug 16, 2008 12:13 PM
mikeylikesit
Jul 9, 2007 09:49 PM
