General Racing/Tech General talk about Racing or help setting up your car
1/4 mile ?
Old Apr 11, 2007 | 06:52 PM
muscleman's Avatar
Default 1/4 mile ?
ok i ran a 14.8 and a 15.01 ... just figured out the miss was a "misplaced" wire boot. my fault entirely as i put it on a manilfold bolt. LMAO. i feel soo stupid, but it was a cheap fix lol. what kind of times am i lookin at with full MSD ignition, exhaust, intake, shift kit, factory stall, sway bar removed and slicks?
Old Apr 11, 2007 | 06:59 PM
badinfluenceRS's Avatar
Default RE: 1/4 mile ?
What is your setup/specs?
Old Apr 11, 2007 | 07:12 PM
muscleman's Avatar
flowmaster cat back 3"with 80 series crossflow muffler, k&n cai, b&m shift kit, msd coil, dist, cap n rotor, 8.5 mm wires, not sure what im puttin out, never had it dynoed.. im guessing thats what u meant?
Old Apr 11, 2007 | 07:21 PM
whats stock for that car?
Old Apr 11, 2007 | 07:25 PM
Depending on what year it is they run 14.2-14.4...that's when the car is brand new...so maybe low 14's
Old Apr 11, 2007 | 07:26 PM
muscleman's Avatar
stock 275 hp 325 tq
Old Apr 24, 2007 | 01:21 AM
muscleman's Avatar
ok.... i made 2 more passes on sunday... had a better reaction time on my second run with a .106, but my slicks had too much pressure in them at 22 psi
best run was completely the way i would drive it (no slicks, sway bar on, etc.)
R/T .275
60' 2.106
330 5.835
1/8 8.919 @ 80.74mph
1000' 11.59
1/4 13.825 @ 100mph
is this what i should have expected? how hard will it be to get into the 12.9s from here? thanks
Old May 9, 2007 | 06:40 PM
cbr600rx7's Avatar
Good reaction time man. and 13.8 is a hell of a run. How did you come out of the hole and what was the last 1/8 like for you and the car. You might be able to get a little more out of the hole if your getting a good hook up.
Old May 9, 2007 | 07:51 PM
coprunr's Avatar
you should be pullingbetter times than that in the 1/8th ... my car is bone stock (down to a paper air filter) and i have ran a best of 8.82. with the mods you have you should be beating my car not running a tenth slower...
Old May 10, 2007 | 11:05 AM
muscleman's Avatar
hmm... not sure why my 1/8 time was slower... it was street tires @ 20psi, so they were slightly breaking loose.. i tried drag radials at the wrong pressure and ran a 18.33 @ 82mph and spun thru the 1/8 lol.. but the 13.8 run it seemed like when it hit 3rd gear right around the 1/8 mark, it just kinda stopped pulling. didnt really feel like it had anything left. is this just because it is an LT1? is there a way to help this? thanks
