Mechanic hints...
Always block the wheels and use jack stands when working under the car.
Use a big piece of cardboard to lay on when working under the car, if you do not have a creeper. It makes it easier to slide around under there and if the concrete is cold, it allows you stay there a little longer!
My grandfather taught me how to remove bolts that had no top and were screwed into something. Like its just a stick of thread. Take a nut and screw it halfway on then put a second one on and tighten them together. then unscrew the bottom bolt and voila it seats against the second and the bolt screws right out.
well you guys got pretty much everything i could think of except dont work on fords... this time im not bashing but everytime we get a ford in the shop me and my boss complain about how much junk they are seriously we have 6 fords lined up for headgaskets right now and just got 2 done 8 headgaskets in a row seriously stupid fords... ok maybe im bashing
How about,
Whenever your bolting something up that's held on by more than one bolt (which is almost everything), never tightened any of the bolts (including finger tight) until all the bolts are at least started.
Here's one ive heard about a head breaking off of a bolt flush with the surface. It does require a welder but its ingenious. If the head breaks off get a nut with an opening slightly smaller in diameter than the bolt (to prevent from welding to the other surface) and weld the nut to the bolt, let it cool down and now you have a new head. BTW a weld if done right is supposed to be stronger than the metal itself.
