Would like some feedback on my Big Block build
So I've built up my motor to where I feel like I can run it on the street sometimes (mostly just to the track and maybe a weekend cruise) but built mostly for the strip. I've built BBCs before but this one is the biggest one so far. She's a 496.
-GM Gen IV 454 Cast Iron Block
-Ohio Forged 4.25" Steel Crank
-Ohio Forged 6.135" Steel Rods
-Keith Black Forged 4.31" Pistons (10.5:1)
-Quick Fuel 1050cfm QFX Carb (3 circuit w/ Ann boosters)
-HVH Super Sucker 4500 Spacer
-Custom Built Aluminum Heads w/ 325cc Intake Runners (2.30/1.88 steel titanium valves, five angle valve job)
-Victor 454-R Intake (port matched)
-Custom Grind Solid Roller Cam (.636/.636 lift, 264/258 Duration @ .050" lift)
-Comp 1.72 Stainless Rockers
-CSR Electric Water Pump
-Moroso Vacuum Pump
-MSD 6AL-2 Ignition
-MSD Pro Billet Distributor
Its putting out close to 700 horses. But being the power hungry guy I am I'm looking for some ways I could squeeze every last drop of ponies I can out of her. What would you do with this setup? Money isn't too much of an issue. I have about $2000 I can play with. Was thinking about porting out the heads and intake and possible selling the can and going with a little bigger stick. Any input is appreciated thanks.
-Moroso Vacuum Pump
-MSD 6AL-2 Ignition
Thinner headgasket for more compression? What's the ring gap? Might be able to hit it with some nitrous? What size primary on your headers?
Sometimes its not about making more power, but optimizing what you currently have, have you thought about more converter/gear? A good converter will wake a car up something fierce
