What size cam do i use
Old Apr 7, 2008 | 04:35 PM
73camaro's Avatar
Default What size cam do i use
I am purchasing a 383 stroker short block. I have vortec heads,edelbrock intake,and edelbrock 650 cfm carb. What is a good cam size to attain about 400 hp and good torque? Please help out a newbie!!!
Old Apr 7, 2008 | 04:50 PM
73camaro's Avatar
Default RE: What size cam do i use
I also forgot to metion 10 to 1 compression
Old Apr 7, 2008 | 04:55 PM
bowtieguy's Avatar
July 2009 ROTM
call one of the cam makers customer service lines and tell them what you got and what you plan on doing with the car and they can get you closer than billybobjoegeorge..look up compcams or elderbrock and get there phone # and talk to them
Old Apr 7, 2008 | 07:07 PM
GRIFF's Avatar
are they stock vortecs?
Old Apr 7, 2008 | 08:44 PM
73camaro's Avatar
I'm asuming their stock vortec heads. I had a mchine shop build them,I have roller rockers,screw in studs,and guide plates.
Old Apr 9, 2008 | 10:37 PM
CHICKENBBC's Avatar
HOWS THE BUDGET? CAN YOU GO
WITH A ROLLER? COMP MAKES A
LOT OF NICE STREET ROLLERS.
Old Apr 22, 2008 | 02:57 PM
gmaccessoriesstore's Avatar
ORIGINAL: bowtieguy
+1. Call up Edelbrock, Comp Cams, Crane, Crower, etc. and tell them what you've got and what you're doing with the car and they'll make a recommendation based on that info. If you can go with a hydraulic roller cam, that's the route to go. If you're block isn't originally set up for one, you can get a retro fit kit, but they're not cheap. Edelbrock probably has a cam that is matched to that intake/carb combo, so check that out too. Good luck!
Old Apr 23, 2008 | 12:46 AM
Sly vette's Avatar
[sm=exactly.gif][sm=icon_ladiesman.gif]
Sly
Old Apr 26, 2008 | 07:45 PM
73camaroSS's Avatar
are you trying to steal my name lol jkd, i would do what these other guys said. good luck, get some vids when you get it running.
Old Apr 26, 2008 | 08:49 PM
kyphur's Avatar
Yes, call them up. Crane Cams, Edelbrock and Comp Cams all have good tech support/cam guys that will point you in the right direction. Called a couple of times to find parts that they've renamed/renumbered to replace stuff I have from a long time ago and they were very helpful.
