V6 to V8 Conversion
Old Apr 23, 2012 | 06:35 PM
davbell22602's Avatar
Default V6 to V8 Conversion
What all has to be swapped out when changing from a v6 to v8 on a 92 R/S 3.1L? I know the engine and trany have to changed out. What about the rearend? Can I still the same rearend?
Old Apr 26, 2012 | 12:49 PM
Anybody?
Old Apr 26, 2012 | 02:26 PM
MKCoconuts's Avatar
Rearend can stay the same. All were ten bolts. Depending on what transmission you go with, you may need a different drive shaft. I would think the front k-member and suspension would need swapped too to handle the extra weight of the V8.
Old Apr 27, 2012 | 04:24 AM
Camambro's Avatar
April 2012 ROTM
It depends on what your swapping into it
Old Apr 27, 2012 | 05:54 AM
92 3.1L camaro R/S automatic
Old Apr 27, 2012 | 09:28 AM
MKCoconuts's Avatar
That's what you're pulling out of it, right? What V8 are putting in? 305, 327, 350, 572 (wishful thinking)??
Old Apr 27, 2012 | 10:33 AM
Camambro's Avatar
April 2012 ROTM
what he said^^
Old Apr 27, 2012 | 10:40 AM
Camambro's Avatar
April 2012 ROTM
and you shouldnt have to change out the trans
Old Apr 27, 2012 | 10:46 AM
His V6 trans won't bolt up to a V8, different bellhousing size/pattern.
Old Apr 27, 2012 | 10:49 AM
I'd putting in a 305 or 350.
