V6 performance
Old Apr 24, 2007 | 11:02 PM
JaySan's Avatar
Default V6 performance
I have a 2000 V6 camaro and I am planning to rebuild my engine soon and i wanted to put some high performance parts. What should i buy ?
Old Apr 24, 2007 | 11:53 PM
badinfluenceRS's Avatar
Default RE: V6 performance
I'm going to do the same eventually
www.abbottracingheads.com
They can port your heads in one of 3 stages, ranging from $799-1,600.
They also have Comp cams, port your intake and lots of other stuff
Old Apr 25, 2007 | 01:47 AM
JaySan's Avatar
so would i have to drive to texas to get my engine wit a custom rebuild ? and stage 3 headswould cost me only 1,600?
how much would i be looking at to try to get my car like that firebird? 2,000 or more?
by the way i don't no much about internals, like what does porting mean ?
Old Apr 25, 2007 | 01:57 AM
But for heads and intake, you send in your heads and intake, then basically make them high flow, more efficent (high performance).
I've heard great things about the stage 3 heads, best in the V6 world...
I plan on getting the Stage 3 Heads, Ported Intake, and Comp ARH Cam
All that should get you 220-235 RWHP
Old Apr 25, 2007 | 02:00 AM
JaySan's Avatar
I want to know ABOUT how much I am lookin at paying. And would I have 2 upgrade my transmission ? if there are such good engine parts?
Old Apr 25, 2007 | 02:14 AM
I'm doing the same thing...here is how I'm pricing it
Stage 3 Heads: $1,600 (abbotts, you can choose stages 1-3, 1 and 2 being cheaper)
Ported Intake: $300 (abbotts)
Comp ARH Cam: $310 (abbotts)
Cam Install Kit: $75 (intense-racing.com)
Also, you might want supporting mods...here's what I plan...
Walbro 255lph Fuel Pump: $140 (zzperformance.com)
GTP 36# Fuel Injectors: $50-100
PCM Tune: $150 (pcmforless.com) YOU WILL NEED THIS
If your doing all this engine work, you'll want a high flow exhaust and intake...so Headers, Cat, Catback, CAI
Old Apr 25, 2007 | 02:22 AM
JaySan's Avatar
ok so if i do this
Ported Intake: $300
Comp ARH Cam: $310
would i still need the PCM flashed because I have a hypertech programmer?
I already have flowmasterexhaust and SLP Lid, SLPsmooth rubber bellows,and SLP CAI, with pacesetter headers. I am covered ?
What would be the advantage to those supporting mods?
Old Apr 25, 2007 | 02:49 AM
I'm not sure what the hypertech programmer covers, I know a HP or DHP would, but those are far more advanced than the hypertech.
You could leave the stock fuel system, but you would be maxing it out...
If your going to spend all that money on the heads etc, it would be smart to get it's full potential and not choke it off...
SO, I would say yes to both, pcm tune (or check to see if hypertech can adjust the mods into a tune) and I would dish out the extra $200 for the fuel upgrades for sure
Other than that, I'd say your set
Old Apr 26, 2007 | 12:35 AM
JaySan's Avatar
So if I leave the stock fuel system how much HP am I screwing myself out of ?
Old Apr 26, 2007 | 12:53 AM
idk, DEFINITELY UPGRADE though...like I said before, compared to what your dishing out, $200 tops will be worth it.
Example of what I'm trying to say, it would be like having a 4" CAI tubing, but then sticking a plate w/ a 2" hole in the tubing, basically it will choke off your potential, can't say exact power loss, but it will be worth it...
