tunnel intake?
Old Oct 11, 2007 | 10:53 AM
littleredcar's Avatar
Default tunnel intake?
i know of a tunnel ram intake with two holley four bbl. double pumper carbs for dirt cheap. but i was talking to a buddy about putting the set up on my 350 and he said it prolly wouldn't perform all that well unless i cammed it and redid all the valves. is ths true or not?
Old Oct 11, 2007 | 02:27 PM
SickSickSick's Avatar
Default RE: tunnel intake?
besides the fact that you would be dumping way too much fuel,the runners on a tunnel ram are huge. without major mods your air velocity would drop to nil. mine is cammed and valved to the max and the tunnel ram only makes about a half sec difference over a standard single or dual plane high rise. you will find alot of arguement over the use of a tunnel ram. unless you have actually raced one your just blowing air. Sick
Old Oct 12, 2007 | 10:17 AM
i think i will buy it as it is only 100$ and wait for a while till i am ready to modify my engine to that point, thanks for the info
Old Oct 13, 2007 | 10:56 PM
middleagecrisis's Avatar
I rana Weiand tunnel ram with 2 x 600 vacuum secondaries ona 406 small block. The Weiand has smaller runners than most, so it came on a little earlier (3500 rpm). They look cool, but you'll get better overall performance with a good single 4 barrel intake like an air-gap, victor jr, etc. My .02 worth.
Wayne G
Nov 15, 2013 08:11 PM
78 on my plate
Dec 2, 2012 04:14 PM
chernmax
Oct 10, 2012 02:13 PM
Bad_Z28
Mar 12, 2011 07:19 PM
SickSickSick
Apr 26, 2006 02:58 PM
