Strokin a 305/has anyone done it?
Old May 16, 2008 | 09:37 PM
Roy's Avatar
Roy
Default Strokin a 305/has anyone done it?
Call me crazy but I've never built a bottom end and I have a set of redone GM 601 Hipo 305 heads and Comp Cams 1.6 roller rockers. I think the combo with an Edelbrock Performer RPM I have and a good Comp cam would do well in my 3rd Gen.
Any input would be appreciated or I could build a 350 bottom end with the GM 601 heads? I think the 335ci stroked 305 would match the 601 heads very well as I'm preping to port and polish them.
Thanks,
Roy
Old May 23, 2008 | 10:44 PM
GRIFF's Avatar
Default RE: Strokin a 305/has anyone done it?
There has been alot of discussion about the 350 tpi head on other forums personally I think it is a great head for a 305 but for a 350 the vortec is a much better choice. Stroking a 305 is interesting but you just will not be at where you would be with a 350. It just because the bore is smaller and you can get head to flow more air into a 350 than a 305 all things being equal. To be real straight with you check on http://www.hotrodders.com/forum/login.phpI think the guys name is fbird he seams to have good experience with the 305 head.... but I personallly believe when you add every thing up the vortec is more cost efficient for the 350. Good luck
Old May 24, 2008 | 07:38 AM
Roy's Avatar
Roy
Thanks again Griff, you are correct in that a 350/383 compared to the 305/335 is a far superior combination. New plan: port & polish the 601 heads,install comp 1.6 roller rockers with correct length pushrods and springs to ride on my Edelbrock Performer Cam [will net .448/.472] and Performer RPM intake and run the thing untill I build a 350/383 or it "blows up" This combo should yeild @ 275 hp and Tq and be ok for the time being.
Thank you,
Roy
