steel for forged crank
RE: steel for forged crank
Depends what you mean by Steel. Forged Cranks are Steel amd Cast Cranks are also Steel/Iron. If you mean which is Stronger that is another Question and a Forged part will always be stronger. A stock SBC chevy will have a Cast Steel or Iron crankshft
well how do i tell if i got the stronger one..cause im gonna put this engine in a 87 s-15...i want it to be as strong on the bottom end as possible... cause i hear people say building an engine without building the bottom of it is a waste....
keep in mind this is my first time building and engine...i do have help with it....
thank you
jason
thank you
jason
why do you say that you dont think i will be making that much power???...
ORIGINAL: blackz87
It will not make much diffenence which one it is because I do Not think you will be making that much power. My opinion. Again I would think its a Cast nodular Iron crank.
To need a forged crank, you will really need serious power, as a first time builder, its doubtfull that you will build an engine over 4-500 hp, you might get into problems with engines with more power than that but even then you could still be fine.
