Starting Problems!
Starting Problems!
I have a 02 ss with about 66,000 miles. Recently I have had problems starting the car. All the lights will come on, but the car won't start. It won't click or anything, but after 15-20 turns of the key it'll start. Any ideas? Help is very much appreciated. Thanks!
Hey I had the same problem you did - from what I've seen on here it's pretty common. Anyways first thing you should do is check your battery connections, clean them off if theres anything on them and even if they don't look dirty you might as well clean them.
Also what condition is your key? If the chip in it is messed up your car won't start and you'll probly see a yellowish light on your dash when you turn your key that says 'security'. If thats it replace the key.
Could be the starter too - it's easy enough to pull off, just gotta have the car up on ramps and the right tools/strength. It's like two bolts and some nuts/wires and possibly a heatshield you'll have to pull off to get to it. Anyways if you pull that off and take it to a parts store they should be able to check if its working. I replaced mine and haven't had any starting problems since, I really hope its gone. Ran me like 170 for the starter.
I actually never got around to replacing my beat up key lol.
The security light should pop up for a second right when you turn your car on but go off right after - if it's popping back up when you turn the key to start the engine then there is a problem.
Thats kinda what mine would do - just randomly it wouldn't start, I'd like grab a pop at a gas station come out and my car wouldn't start so I would hang out in it for a while turning the key and it luckily would start after a while...
I've also heard it could be stuff like bad connections, frayed wires, ignition switch, dirty ground, etc. Good luck!! Definitely get that starter tested.
