-   Engine & Internal (https://camaroforums.com/forum/engine-internal-23/)
-   -   small block numbers-HELP!! (https://camaroforums.com/forum/engine-internal-23/small-block-numbers-help-56369/)
coupeman Oct 25, 2010 05:44 PM
I have a 81 Camaro with a non original engine in it. I cant seem to find out what the engine and heads are so here are all the numbers, hope someone can help. Block casting number is 3970010-alsoA 20 5, these are are on the back of the engine. On the front pad just above the waterpump , under the alt are these numbers, C5B127127 V0127T. Head casting number is 378450 ,also on the heads is GN9T and E 10 79. Cant seem to find out what this is so if anyone can help I would appreciate it. THANKS!!
Camaro 69 Oct 25, 2010 08:55 PM
The "3970010" is a pretty common block, used in 1969 for the 302, and from 1969-80 for the 350.
"A 20 5" is the date code. A=January, 20=day of month, and 5 would have to be 1975 (the only year between 69-80 that ends with a 5).
C5B127127: C= that I'm not so sure about because a "1" instead of C= Chevy (maybe there's a difference because of what it came out of...read on), 5=1975, B= Baltimore, Maryland VIN assembly plant (not engine assembly plant), and the rest is the partial VIN.
V0127T: V= Flint engine Plant, 01= assembly month (January), 27= day of the month, T= truck motor division
The "450" heads were used on 267 and 305 engines. "E 10 79" date code is May 10, 1979.
So...you have a 1975 350 truck engine with 1979 267/305 heads.
Oh yeah, and here's a good link to research from: http://www.chevy-camaro.com/chevy-ca...oding-help.asp
bowtieguy Oct 27, 2010 07:40 PM
You can also look up the numbers at www.mortec.com
Kimberly Morrison Martin Feb 11, 2016 10:02 PM
I have a engine that has 3970010. On front of engine it has Eo329ckl 13j250675. Thank you.
Everett#2390 Feb 12, 2016 05:54 AM
0329 = Mar 29, CKL = 1973 350 California (emissions)
13J = Chev, '73, Janesville WI, vehicle assembly plant.
Thank you '69, for the link.
Kimberly Morrison Martin Feb 12, 2016 10:26 AM
Motor Vin
I have a 350 with 3970010 on back of engine. On front it has V1122tbd and c9f369258. Thank you very mutch.:icon_worthy:
Everett#2390 Feb 13, 2016 01:33 PM
C9 = C-series model truck, 1979
V = Assembly plant Flint, MI
1122 = Nov 22
TBD = 1979 350 4-bbl, 165HP, Federal emissions
You're velcome
Joey Hockett Mar 12, 2017 03:32 PM
i have 2 engine blocks to decode help plz
1122 = Nov 22
You're velcome
Can anyone help me decode 2 engine blocks
First one is 3914660. TO 626 HI
2nd is 3858180. TI 008 HCH
Augster May 11, 2023 09:05 PM
Matching numbers
https://cimg4.ibsrv.net/gimg/camarof...b97f0ac333.jpg
Is this a matching numbers car TIA
Y2Keglide May 11, 2023 09:42 PM
You should start a new thread,this one is over 10 years old.
