Rear Diff. Gears?
RE: Rear Diff. Gears?
ORIGINAL: Auji350
Just Looking to Gain some Bottem end Trq to the RWs. What is a good size of gears to go with and where can i get them??? Thanks!
Yup, my buddie(Previous Owner) Had the 350Fuel injection swapped in. too bad its not carburated, i preferr a carb system, Much more Easier/Convienent to work on. Is it Hard/Expensive to Swtich from FI system to Carb? i was told there's alot of work involved.
But yah What gears would you suggest?
Well you mayhave a 10-bolt 2-series carrier with a possible open rear (no limited slip) . Find a late model 3rd gen3:42 rear axle and swap the whole rear. Otherwise, expect to spend an ton of money on parts and labor. My opinion.
