Question about detonation
Old Aug 11, 2010 | 02:29 PM
kyphur's Avatar
Sounds like you don't have enough timing now.
Old Aug 15, 2010 | 10:13 PM
78LT350's Avatar
I checked timing with the vacuum advance off and it was at 8*, then when I put the vacuum advance back on the timing was still at 8*...Does that sound right?
Old Aug 15, 2010 | 11:12 PM
Yes that's normal, when the advance is hooked up to ported vacuum (no vacuum at idle). Just for fun, you should try hooking your advance up to the full manifold fitting on the carb and see if it makes a difference, one way or the other.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
