propain fueled 350 to gas? pros/ cons please
Old Jun 5, 2008 | 04:26 PM
z28camaroguy's Avatar
Default propain fueled 350 to gas? pros/ cons please
i have a 81 z28 camaro and i can get a good deal on a 88 truck that has a clean 350 in it. the 350 was powered by propain and i was wondering if i convert it back to gas what im looking at.
i want to hear the pros and cons. will i have any problems with rings, scoring or does the propain weaken a 350 internals? i was told that it would have burned cleaner than a gas engine and that the internals would be clean.
i really know nothing of propain fueled motor so any info is greatly appreciated.
Old Jun 5, 2008 | 08:47 PM
Fortee's Avatar
Default RE: propain fueled 350 to gas? pros/ cons please
A propain powered engine?
Old Jun 6, 2008 | 07:18 PM
ok so this truck isa 87 and it is carburated and the fuel lines are caped off and this propain thing goes on the top of the carb. the guy i got it from switched it back to gasoline. i think im going to do a compression test on it and then take off the heads and do a complete engine gasket replacement on it and i plan on putting in a different cam in it as well since i will have it all opened up.
Old Jun 6, 2008 | 10:43 PM
Considering the price of gasoline, ou may want to keep the propane setup. LOL
luciora
May 19, 2010 03:05 AM
LesDrive
May 2, 2010 06:09 PM
Adam78
Dec 13, 2009 12:06 PM
Spartan66
Jul 4, 2007 10:11 AM
microkid
Feb 21, 2007 01:47 AM
