Power Steering Pressure Hose
One of the first problems I noticed when I bought my 91 was a squeal every time I took a sharp turn. We correctly diagnosed it as a leaking power steering hose, but had a difficult time finding the right piece.
For anyone else with a similar problem, here is the part to get: Power Steering Pressure Hose (Part Number: 71422). This part works for either the 5.0 or the 5.7L Z28 engine. It was a cheap fix, only costing $22. When installing it, make sure to keep both opening clean and free of debris and of course make sure it is properly seated before you screw it in.
If you want to order it online or see a picture for comparison, here it is! Hope this saves you some time!
It's really hard to work with a broken Power Steering Hose, it takes a lot of work finding the right parts to fix the problem.
