Ported 305 heads vs Aluminum Promaxx heads
Old Sep 12, 2019 | 10:12 PM
Markheth's Avatar
Question Ported 305 heads vs Aluminum Promaxx heads
I found this forum looking for some dish 4 valve relief piston volume numbers, which I found - sort of. I'm hoping they are 12-13cc.
I'm trying to figure out if I should...
1/ put some ported 58cc 305 heads with 1.94/1.6 valves and a stock gasket or
2/ get some 64cc promaxx 183's (maybe cut to 62) with thinner head gaskets to help keep the compression at 9.5:1 approximately regardless of the heads.
The engine it's going on is a 350 at 040 over with stock replacement pistons (cast dish 4 valve relief), recently rebuilt.
The 305 heads are a little cheaper, which helps me maintain my budget street engine goal, but the promaxx aluminum heads flow really well.
I really have no idea how well the 305 heads will perform compared to those new aluminum heads, which is what i hope I can get a feel for.
The cam it most likely going to be a comp magnum 270H, since it's part of the budget program i'm on and it's available. I also have an edelbrock 7501 ready to go on it and still deciding on a carb.
Does anyone have any experience on how well those ported 305 heads will work in comparison to those aluminum ones? Pros? Cons?
Tcombs911
Dec 24, 2011 05:47 PM
Badrs2810
82-92 V8 Tech
20
May 28, 2010 05:07 PM
80ZJoe
70-81 V8 Tech
16
Mar 14, 2010 08:40 PM
89rscamaro
82-92 V8 Tech
Sep 8, 2007 11:12 AM
ScottD
Nov 25, 2006 09:16 PM
