New here.. I just bought a 87 z28 with 406...
I just bought a 87 z28 with built 406. The previous owner has time slips of consistant mid 7's in 1/8th. Its set up for street/strip. Its my weekend cruiser/toy. Does mid 7's sound about right? Is there anything I can do to improve performance/times? W hat should it be running?Motor and tranny has 200 miles. Here is the mod list
400 SBC bored .030 over to make a 406.*
It has the 502 stamped block.*
Has a new Scat crankshaft.*
The pistons are Speed Pro +12.5 dish Hyperutectic and chromoly rings.*
All new rod and main bearings as well as cam bearings.*
Fel-pro gaskets.*
Moroso high volume oil pump as well as a Moroso 7 quart pan.*
The cam is a Comp Xtreme 284H with matching lifters.*
Heads are Dart Platinum 215 intake runner and 72cc.*
Aluminum radiator.*
New TCI Flexplate and Proform Balancer
Distributor is an MSD Streetfire and Taylor 8mm wires.*
Has Holley 110 gph fuel pump as well as a Holley fuel pressure regulator.*
Edelbrock Performer RPM intake and Performer 750 Carb.*
Hooker Comp ceramic coated headers going into 3 inch dual exhaust Moroso Spiro flow mufflers.*
Freshly rebuilt turbo 350 with a stage 2*shift kit
Stall converter is a Boss Hog 3200 rpm.*
New driveshaft and heavy duty u-joints.*
New UMI powder coated cross member and adjustable torque arm. 373 Auburn locker.
Power brakes, disc up front drum rear.*
The suspension has all been upgraded also with new shocks in the rear as well as new end link kits front and rear.*
Car also has a Harwood 3 inch cowl hood.*
New mickey thompson street slicks
Fel-pro gaskets.*
Aluminum radiator.*
You can calculate your approximate 1/4 mile time based on using your 1/8 mile time and speed: Wallace Racing - 1/8th Stats to 1/4 Stats Calculator
