New here.. I just bought a 87 z28 with 406...
I just bought a 87 z28 with built 406. The previous owner has time slips of consistant mid 7's in 1/8th. Its set up for street/strip. Its my weekend cruiser/toy. Does mid 7's sound about right? Is there anything I can do to improve performance/times? W hat should it be running?Motor and tranny has 200 miles. Here is the mod list
400 SBC bored .030 over to make a 406.* It has the 502 stamped block.* Has a new Scat crankshaft.* The pistons are Speed Pro +12.5 dish Hyperutectic and chromoly rings.* All new rod and main bearings as well as cam bearings.* Fel-pro gaskets.* Moroso high volume oil pump as well as a Moroso 7 quart pan.* The cam is a Comp Xtreme 284H with matching lifters.* Heads are Dart Platinum 215 intake runner and 72cc.* Aluminum radiator.* New TCI Flexplate and Proform Balancer Distributor is an MSD Streetfire and Taylor 8mm wires.* Has Holley 110 gph fuel pump as well as a Holley fuel pressure regulator.* Edelbrock Performer RPM intake and Performer 750 Carb.* Hooker Comp ceramic coated headers going into 3 inch dual exhaust Moroso Spiro flow mufflers.* Freshly rebuilt turbo 350 with a stage 2*shift kit Stall converter is a Boss Hog 3200 rpm.* New driveshaft and heavy duty u-joints.* New UMI powder coated cross member and adjustable torque arm. 373 Auburn locker. Power brakes, disc up front drum rear.* The suspension has all been upgraded also with new shocks in the rear as well as new end link kits front and rear.* Car also has a Harwood 3 inch cowl hood.* New mickey thompson street slicks |
Sounds fair, do you have a 1/4 strip near by?
You can calculate your approximate 1/4 mile time based on using your 1/8 mile time and speed: Wallace Racing - 1/8th Stats to 1/4 Stats Calculator
No 1/4 mile track. So does numbers sound right? Right now its running a street tune on 93. Is there any room for improvement according to mods? If so how? Motor is making aproximately 450hp.
It don't sound bad, I'd take it to the track and run it..
