need 383 stroker advice!!
Old May 23, 2009 | 05:34 PM
chevy21's Avatar
Default need 383 stroker advice!!
hey guys im looking to build a 383. I was wondering what the stroke on the crank is supposed to be.. is it 3.75? or something else? also what should the rod length be 5.7? is there anything else I should know about building this motor? other than rods built for clearance?
Old May 24, 2009 | 07:35 AM
z28rob18's Avatar
the stroke is 3.75. and for rods you can use 5.7" or 6" most of the big power ppl use 6" because with the longer rod you take some stess off of the cylinder wall. the block may need a bit more clearancing with the 6" but imo if your building it then build it to last.
and the only other thing i can tell you about building it dont go into the project planning on spending $4k and only having $4k go in with a plan/budget but be prepared to spend more.
Old May 24, 2009 | 09:19 AM
robmnrd's Avatar
rob is right about the budget. Usually a good rule of thumb is to add up how much you think everything will cost, double it, and that's closer to what it will all cost. :P
Old May 24, 2009 | 08:29 PM
chevy21's Avatar
yea im building a motor for the ages here. im building everything hydrolic roller. with a 750 cfm holley double pumper. i just can't seem to figure out what cam/heads combo I wanna go with =[
Old May 24, 2009 | 08:31 PM
chevy21's Avatar
i already have everything else lined up. 350 turbo tranny built by the best im my region with b&m shift kit. 373 rear end. 90/10 springs up front 50/50 coilover in the back. alum radiator, driveshaft, and waterpump. all put into an 86 ircon.. oh man I can't wait.
Old May 24, 2009 | 08:36 PM
daragez's Avatar
that's good!...good luck to you!...
Old May 24, 2009 | 11:11 PM
Give this a look....when you have a lot of time on your hands:
Building a 383
Old May 28, 2009 | 12:14 PM
chevy21's Avatar
ok reading your guys advice makes me pose to more questions. why 6.0 rods over 5.7... what is the benefit? also has anyone ever supercharged a 383 or is the stroke to long and weak for the xtra combustion?
Old May 28, 2009 | 12:53 PM
z28rob18's Avatar
i explained the 6" rod already less stress on the side of the cylinder wall. and you can definatly supercharge it just need the pistons for the right compression
Old May 28, 2009 | 10:50 PM
chevy21's Avatar
how would one go about buying the right piston?
