Looking for a 6 speed transmission
Old Apr 30, 2009 | 07:59 PM
Hippie23d's Avatar
Default Looking for a 6 speed transmission
I have a 1987 Camaro with the 4 bbl 305 motor with a 5 speed standard transmission. I'm putting together a 350 engine that I plan on putting in the car soon. Is there any 6 speed standard transmission that will bolt up to an older Chevy 350 that will work in a Camaro?
Old May 1, 2009 | 01:08 PM
z28rob18's Avatar
im not to sure but an lt1 block is lik a sbc id do a little research if i was you but an lt1 t56 may work. check with companys that make/build them and all. the t56 would be ur best bet though
Old May 4, 2009 | 04:14 PM
kyphur's Avatar
What he said... You can take the old LT1 bellhousing and use it to mate up to the old GenI sbc. I have one sitting in my storage that a friend gave to me that I was going to use for a swap.
In fact I think you can take the bellhousing from the old T5 and move it to the T56 but I'm not 100% sure on that so don't quote me. There's a post that I have on here somewhere with some links in it that Specter was nice enough to give me from a few months back. Do a search on my name and "swap" and you will probably find it pretty easily.
Ha, it wasn't as easy to find as I thought...
Here you go...
https://camaroforums.com/forum/engine-internal-23/manual-transmissions-32726/
Old Aug 21, 2009 | 12:35 PM
Black91Camaro's Avatar
I have a t56 in my 3rd gen and it does great. You should have no problem with this swap.
royrois
Aug 20, 2013 09:03 PM
Nomad
Oct 4, 2011 11:13 PM
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
96CamaroZ28
May 12, 2011 10:10 PM
