here's what I have. Any input on needed parts plz
I am usually a read only member. Well anyways im finally doing my motor and I bought this stuff after being on the phone w/ the summit guy for 3hrs. Here is what i have. '92 four bolt main 1 pc rear seal, It's done-he took2-3 thous. off deckto clean it, and 30 thous. out as per rotating assem. He "finished" the crank and checked the balance of the whole assem. Now he is tearing down my new heads to port and polish. Of courseI have all newARP stud and bolt kits, as well as some non perf. must haves. I have the March underdrive pulley set already but I will need all new ignitionparts. I need to work out the inj. size as well as the throttle body size and maybe anything else I have forgotten.Any help in this matter would be greatly appreciated. Thanks in advance! P.S. How about an est. on torq and hp#'s as I am hoping for 450tq and 400hp.
-Eagle Street & Strip assemblies #ESP-B13055L030 383 stroker kit (inter balanced).64cc heads=10.9 to 1/76cc heads= 9.6 to 1.
-Trick Flow Super 23 Street/Strip # TFS-30400015-CNC
72cc 2.02 int/1.6 exh (any est on comp ratio???)
Intake runner vol. 195cc
Exhaust runner vol. 75cc
-COMP Cams Xtreme Fuel Injected Camshafts #CCA-08-466-8
Durationat050inchLift: 218 int./224 exh.
Lobe seperation 113 deg.
RPM range 1800 to 5800
-Holley Stealth ram manifoldand plenum #WND-7540
-Holley efi fuel rail kit w/ adj fpr #HLY-534-186
-Summit 1.6 roller rockers
-Summit roller timing set
-Melling high vol/press oil pump
-Moroso 6qt oil pan
-Moroso oil pump pickup
-Hedman Street Hedders full length # HED-68466
-Moroso 6qt oil pan
l3loodred
01-21-2010 06:02 PM
