Estimated HP after Stroking an LT1
hi peeps,
what would you think my wheel hp would be if i stroked my 1996 Z28 5.7 LT1 into a 383 ?????
i already have a big MAF installed with an intake system and edelbrock short headers with a flowmaster muff..
and would i be able to do my bottom part of the block only and keep all the rest stock, as in the cam and heads and stuff?
thanks
thanks
If you're going to install a stroker kit to a 383, you're going to have the motor out anyway. At this point, you might as well have the heads worked, or get better heads, or get a cam and some valvetrain, etc. As long as it's out, invest a bit into the top end.
Displacement is great, but if you don't have the flow, good luck gettin' more go. I can rhyme
