Engine opinions
Old Oct 13, 2006 | 01:04 AM
GRIFF's Avatar
Default Engine opinions
I am looking for a few opinions on a engine I just put together, it is a budget engine just want to know if I made any major blunders. Here are the specs:
GM 511- 400 BLOCK,block is 1/2 hard blocked, bored 30 over, studded, line honed, decked to 9.010, Eagle 6" h beam rods, eagle 3.75
forged internally balanced crank, balanced, Probe flat top pistons, melling select oil pump, 6.75" balancer sfi, studded deck, deck
plugs, hurricane intake, dart iron eagle platinum 64 cc/ 230 cc heads 2.08 1.6, comp promagnum 1.6 rockers, 80 wall comp pushrods 150 over, msd pro dist, crane fireball 2 stage box. crane fireball coil. .3500 stall 10 x 29 slicks Crane solid cam http://www.cranecams.com/index.php?s...21&lvl=2&prt=5 Have not decided on a carb yet. Compression is 11.5:1 Car is a 79 camaro,4.56 gear th 350 mostly running 1/8th mile
Old Oct 13, 2006 | 02:18 AM
uncle bill's Avatar
Default RE: Engine opinions
Sounds like a good solid combination. Camshaft is a bit on the soft side. You'd do better with something around 260 degrees @ .050 intake and 270 degrees exhaust on a 110 - 112 lobe seperation. You've got some pretty big heads and cubic inches so that might swallow up Your cam. I'd put an 850 - 900 cfm carb on it. Man, why didn't You use a roller? If You'd look at a lobe profile and see how long the cam stays at full lift and how fast it accelerates the lifter, You'd be amazed by the difference between a roller and a solid. Probably worth 75 + HP on a motor like that. I think that it'll make about 550 Hp @ 6500 and 510 ft/lbs tqe @ 5000 with what You have now, maybe even a bit more. Anyway You look at it, It'll be a stout runner. Good luck with it.
Old Oct 13, 2006 | 02:40 PM
GRIFF's Avatar
I should have asked you the question before I bought desktop dyno, you are within 10 hp of what it says. We were planning on going roller but started to get a bit low on our budget and the solid was cheaper. Hopefully we can go roller when the budget allows, I have a .649 lift roller but it is a inverse radius cam I was a little afraid to try it. Actually I am glad you think 550 is the number because that is what we were shooting for. Thank you very much for looking it over and the suggestions. Do you think it could break into the 10s in a 3400# car??
Old Oct 13, 2006 | 02:47 PM
shnormo's Avatar
The larger displacement does allow for a larger cam. Don't over carb a motor, so I personally think 800-850 CFM carb would suit your application. Did you get headers? Flowtech's Tri-y's are my personal favorite.
Old Oct 13, 2006 | 11:56 PM
GRIFF's Avatar
I have a set of flowtech afterburners they appear to be to small, the port dosnt match to the header very well.
Old Oct 14, 2006 | 02:03 AM
uncle bill's Avatar
Hooker or Heddman Competition Headers with a 1 7/8 primary and a 3 1/2 or 4 inch collector will work the best. Pricey but worth it. It's pretty hard to overcarb that engine, just don't go crazy with the jets. I wouldn't put the roller in just yet. Run it awhile with the solid since it's already in. That inverse radius You spoke of, do You mean it's a small base circle or that it has the inverse ramps on the acceleration side of the lobe. If that's a Crane inverse roller, They work great, just remember to check valve clearance and run the right spring pressure. Don't be afraid of 225 - 250 pounds on the seat, They'll settle down a bit after running time. What's the duration @ .050" and lobe seperation ?
Old Oct 14, 2006 | 02:04 AM
uncle bill's Avatar
Oops, forgot about the times. Tell me more about the Car, trans, gears, chassis setup etc.
Old Oct 14, 2006 | 03:01 AM
GRIFF's Avatar
Its a Lazer cam #2970816 here is a link to the specs http://www.lazercams.com/CamTables.html. The car is a 79 camaro it has a 12 bolt rear with 4.56 gears and a posi unit, trans is a th350 with a 3500 stall, battery is relocated to the trunk, it has a 7 gallon fuel cell, 8 point roll bar, frame is tied. the car is stripped out a fiberglass frontend is in the future. I am estimating the car to weigh 3400 lbs. The rear tires are 29 x 10 hoosier slicks. Factory leaf rear(new) with poly bushings 4 degree pinion angle, traction bars, drag shocks.
Old Oct 14, 2006 | 03:44 AM
uncle bill's Avatar
10.80's @ 126 quarter / 7.10 @ 99 eighth in this trim.
Old Oct 14, 2006 | 11:14 AM
GRIFF's Avatar
That will work great!!! thanks again... what did you think of the roller cam, Ive been aquiring parts for the next build some of the sprint car guys I know are getting out and the gave me some of their spare stuff, 2 sets of offset roller lifters, two sets of valve springs, four sets of JE pistons(need checked over but look pretty good) this time I am going to try to find an aftermarket block.
6.5 Detroit TD
Mar 22, 2011 10:20 AM
Rix_74
Jun 17, 2009 09:31 AM
jtgarcia2002
Apr 15, 2009 10:52 PM
TwoToneVert
Nov 26, 2006 11:55 AM
